주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5140 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5140 Keyboard Replacement: 2 단계, 이미지 2/2
    • Using hands, gently pull keyboard out of device.
결론
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
Cameron Chapman
회원 가입일: 09/27/17
533 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 489
