주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5140 RAM Replacement
필요한 것
  1. Toshiba Satellite C55-A5140 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Flip the device over, and unscrew the 5mm PH#1 screw on L shaped access panel.
    • Screw will not come out of access panel: simply unscrew until loose.
  2. Toshiba Satellite C55-A5140 RAM Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to open access panel by sliding it into notch near screw and prying access panel(L-shaped) away from device.
    • Pull panel completely free from device and set aside.
  3. Toshiba Satellite C55-A5140 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C55-A5140 RAM Replacement: 3 단계, 이미지 2/2
    • Push the two metal tabs on each side of RAM stick outward (away from RAM) to unlock from tray.
    • Pull ram straight out (away from connector) to remove.
결론
To reassemble your device, follow these instructions in reverse order. After sliding new RAM into tray, push straight downward to lock it into position.
Cameron Chapman
회원 가입일: 09/27/17
533 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 399
