소개
This guide will show you how to remove or replace the battery of the Toshiba Satellite C55-A5286 laptop. No tools are necessary for this procedure.
Be sure to unplug the AC adapter and all other components from the laptop.
Slide the battery release tab away from the center of the laptop and hold it in place.
You have now taken the battery out of the laptop. To reassemble your device, follow these instructions in reverse order, being sure to snap the battery back into place.
다른 한 분이 해당 안내서를 완성하였습니다.
