주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5286 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55-A5286 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Unplug the AC adapter and all other auxiliary components from the laptop.
  2. Toshiba Satellite C55-A5286 Hard Drive Replacement: 2 단계, 이미지 1/1
    • There is a removable panel on the underside of the laptop with one 5-mm screw holding it in place.
    • Use the screwdriver to remove the screw and then remove the back panel.
  3. Toshiba Satellite C55-A5286 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Underneath this panel is a silver square with rubber around the edges. This is the hard drive. On the side of the hard drive nearest to the manufacturer’s label, there is a large, flat 8-mm screw that is holding the hard drive in place.
    • Use the screwdriver to remove the screw.
  4. Toshiba Satellite C55-A5286 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicole Zellers
회원 가입일: 11/06/18
265 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Hovde Fall 2018 IUPUI, Team S1-G5, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G5
2 회원들
안내서 9개 작성하였습니다
댓글 한 개
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
William Totman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 797
