주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5286 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5286 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-A5286 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Carefully slide the optical drive out of its place in the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicole Zellers
회원 가입일: 11/06/18
265 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Hovde Fall 2018 IUPUI, Team S1-G5, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G5
2 회원들
안내서 9개 작성하였습니다
댓글 한 개
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 298
