소개
This guide will help you if you need to replace the battery in your laptop. Replacing the battery will fix any issues caused by a old or faulty battery. It is very straightforward and can be completed regardless of technical knowledge or skill level.
필요한 것
With the Laptop off, turn it over.
The battery is located next to the screen hinges.
Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
다른 한 분이 해당 안내서를 완성하였습니다.
