주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5300 Fan Replacement
필요한 것
  1. Toshiba Satellite C55-A5300 Fan Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-A5300 Fan Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-A5300 Fan Replacement, Battery: 1 단계, 이미지 3/3
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Fan Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C55-A5300 Fan Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C55-A5300 Fan Replacement: 2 단계, 이미지 3/3
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Fan Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Fan Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Fan Replacement: 5 단계, 이미지 1/1
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Fan Replacement: 6 단계, 이미지 1/1
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Fan Replacement, Fan: 7 단계, 이미지 1/1
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Fan Replacement: 8 단계, 이미지 1/1
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Fan Replacement: 9 단계, 이미지 1/2 Toshiba Satellite C55-A5300 Fan Replacement: 9 단계, 이미지 2/2
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Fan Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55-A5300 Fan Replacement: 10 단계, 이미지 2/2
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
결론
David Burleson
회원 가입일: 09/09/18
391 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 381
