주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5310 Fan Replacement
필요한 것
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement: 4 단계, 이미지 2/2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: 6 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement, Fan: 6 단계, 이미지 2/2
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: 7 단계, 이미지 1/1
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: 8 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement: 8 단계, 이미지 2/2
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: 9 단계, 이미지 1/1
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement: 10 단계, 이미지 2/2
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: 11 단계, 이미지 1/1
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: 12 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Fan Replacement: 12 단계, 이미지 2/2
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: 13 단계, 이미지 1/1
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: 14 단계, 이미지 1/3 Toshiba Satellite C55-A5310 Fan Replacement: 14 단계, 이미지 2/3 Toshiba Satellite C55-A5310 Fan Replacement: 14 단계, 이미지 3/3
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: 15 단계, 이미지 1/1
    • Lift from corresponding sides of the fan and it'll pop right out.
결론
Robin
회원 가입일: 02/08/18
181 평판
안내서 1개 작성함
Sam Houston State, Team S16-G1, Nardone Spring 2018 Sam Houston State, Team S16-G1, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 543
