주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5310 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Optical Drive Replacement: 4 단계, 이미지 2/2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-A5310 Optical Drive Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
결론
Kari Rodgers
회원 가입일: 02/08/18
482 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S16-G1, Nardone Spring 2018 Sam Houston State, Team S16-G1, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 319
