주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-A5310 RAM Replacement
필요한 것
  1. Toshiba Satellite C55-A5310 RAM Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-A5310 RAM Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-A5310 RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 RAM Replacement, RAM: 2 단계, 이미지 1/2 Toshiba Satellite C55-A5310 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Remove one JIS #000 screw.
    • This screw does not come out all the way, but you will still be able to open the back panel.
  3. Toshiba Satellite C55-A5310 RAM Replacement: 3 단계, 이미지 1/1
    • Use the plastic opening tool to pry the panel open. Be sure to do this on all four sides. Then the panel will lift off.
  4. Toshiba Satellite C55-A5310 RAM Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C55-A5310 RAM Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C55-A5310 RAM Replacement: 4 단계, 이미지 3/3
    • Take the nylon spudger, and push the prongs so that it releases the RAM.
  5. Toshiba Satellite C55-A5310 RAM Replacement: 5 단계, 이미지 1/3 Toshiba Satellite C55-A5310 RAM Replacement: 5 단계, 이미지 2/3 Toshiba Satellite C55-A5310 RAM Replacement: 5 단계, 이미지 3/3
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
결론
Kari Rodgers
회원 가입일: 02/08/18
482 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S16-G1, Nardone Spring 2018 Sam Houston State, Team S16-G1, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G1
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 325
