주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
필요한 것
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 3 단계, 이미지 3개 중 1개 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 3 단계, 이미지 3개 중 2개 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: 3 단계, 이미지 3개 중 3개
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
    to remove the back, you have to remove all the philips screws. and then, it took some gentle but firm prying to get the back off.
    tom - 답글
    Missing steps. You need to take the cover off by removing all the screws and prying gently.
    it is useless and unacceptable to have a guide without showinng all the steps!!! Please do better in the future!
    gerasim - 답글
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Pablo Andrade
회원 가입일: 02/14/18
1,081 평판
안내서 7개를 작성함
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 회원
USFT-NANCE-S18S3G1
4 회원들
안내서 22개를 작성함
댓글 2개
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - 답글
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
Dulce Martinez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 20
지난 30일: 37
전체 시간: 4,700
