주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-B5200 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Satellite C55-B5200 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Satellite C55-B5200 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite C55-B5200 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Pablo Andrade
회원 가입일: 02/14/18
1,126 평판
안내서 7개를 작성함
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 회원
USFT-NANCE-S18S3G1
4 회원들
안내서 22개를 작성함
1가이드 댓글
gracias por la guía
Mark Puga - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 5
지난 30일: 15
전체 시간: 4,312
