소개
A guide on how to replace the optical disk drive on a Toshiba Satellite C55-B5200 laptop.
필요한 것
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Make sure device is turned off and unplugged
Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
다른 한 분이 해당 안내서를 완성하였습니다.
