주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-B5302 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Hard Drive Replacement: 5 단계, 이미지 2/2
    • The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
  6. Toshiba Satellite C55-B5302 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Gently pull the hard drive away from the connection to remove it from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jeff Sims
회원 가입일: 10/02/18
242 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 1,046
