이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
Pull the battery from the back of the laptop for removal from the laptop.
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
Gently pull the hard drive away from the connection to remove it from the laptop.
다른 3명이 해당 안내서를 완성하였습니다.
