소개
These are the steps for removing the screen bezel from your Toshiba Satellite C55-B5302 laptop. Before starting, make sure you have your Phillips size #0 screwdriver and a systematic way to keep all the unscrewed screws as there are going to be a large number of them with different dimensions. Since we will be working in close proximity with the monitor screen, you should be careful not to scratch it.
필요한 것
After the fan has been removed, lift the hinge so as to get access to the parts below it.
Remove the the black colored cable that is now exposed.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Sir how will I find screen strip of toshiba c55-b1326
Sir how can I find screen strip of toshiba c55-b1326
