주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-B5302 Webcam Replacement
필요한 것
  1. Toshiba Satellite C55-B5302 Webcam Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement, Battery: 1 단계, 이미지 2/2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Webcam Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Webcam Replacement: 3 단계, 이미지 1/1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 4 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 4 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement, Fan: 4 단계, 이미지 3/3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Webcam Replacement: 5 단계, 이미지 1/1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Webcam Replacement: 6 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 6 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 6 단계, 이미지 3/3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Webcam Replacement: 7 단계, 이미지 1/1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 8 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 8 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: 8 단계, 이미지 3/3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Webcam Replacement: 9 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 9 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 9 단계, 이미지 3/3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Webcam Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement: 10 단계, 이미지 2/2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Webcam Replacement: 11 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement: 11 단계, 이미지 2/2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Webcam Replacement: 12 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 12 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 12 단계, 이미지 3/3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Webcam Replacement: 13 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 13 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 13 단계, 이미지 3/3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Webcam Replacement: 14 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 14 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 14 단계, 이미지 3/3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 15 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 15 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: 15 단계, 이미지 3/3
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Webcam Replacement: 16 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement: 16 단계, 이미지 2/2
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Webcam Replacement: 17 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 17 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 17 단계, 이미지 3/3
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Webcam Replacement: 18 단계, 이미지 1/3 Toshiba Satellite C55-B5302 Webcam Replacement: 18 단계, 이미지 2/3 Toshiba Satellite C55-B5302 Webcam Replacement: 18 단계, 이미지 3/3
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Webcam Replacement: 19 단계, 이미지 1/2 Toshiba Satellite C55-B5302 Webcam Replacement: 19 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Browning
회원 가입일: 03/25/19
310 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Henning Spring 2019 IUPUI, Team S1-G3, Henning Spring 2019 회원
IUPUI-HENNING-S19S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,517
