주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
필요한 것
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: 1 단계, 이미지 2/2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 2 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 3 단계, 이미지 1/1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 4 단계, 이미지 1/3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 4 단계, 이미지 2/3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): 4 단계, 이미지 3/3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 5 단계, 이미지 1/3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 5 단계, 이미지 2/3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: 5 단계, 이미지 3/3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
결론
Jessie
회원 가입일: 10/03/18
255 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 1,096
