주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5240 RAM Replacement
필요한 것
  1. Toshiba Satellite C55-C5240  RAM Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-C5240  RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240  RAM Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C55-C5240  RAM Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C55-C5240  RAM Replacement: 2 단계, 이미지 3/3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240  RAM Replacement, Back cover: 3 단계, 이미지 1/2 Toshiba Satellite C55-C5240  RAM Replacement, Back cover: 3 단계, 이미지 2/2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240  RAM Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C55-C5240  RAM Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C55-C5240  RAM Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240  RAM Replacement, RAM: 5 단계, 이미지 1/3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: 5 단계, 이미지 2/3 Toshiba Satellite C55-C5240  RAM Replacement, RAM: 5 단계, 이미지 3/3
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  6. Toshiba Satellite C55-C5240  RAM Replacement: 6 단계, 이미지 1/1
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
결론
Angela Rodriguez
회원 가입일: 02/28/17
261 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 회원
USFT-NANCE-S17S1G5
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 18
전체 시간: 1,466
