주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5240 Motherboard Replacement
필요한 것
  1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Motherboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 2 단계, 이미지 3/3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: 3 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: 3 단계, 이미지 2/2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Motherboard Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: 5 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: 5 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: 5 단계, 이미지 3/3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Motherboard Replacement: 6 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 6 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 6 단계, 이미지 3/3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Motherboard Replacement: 7 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 7 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 7 단계, 이미지 3/3
    • Peel off the rubber hard drive mount.
  8. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: 8 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: 8 단계, 이미지 3/3
    • Slide the disk drive to the right and gently lift up the disk out the laptop.
  9. Toshiba Satellite C55-C5240 Motherboard Replacement: 9 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 9 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 9 단계, 이미지 3/3
    • Disconnect the 5 ribbon cables.
    • To remove, unlock the latch of each ribbon and pull it out.
  10. Toshiba Satellite C55-C5240 Motherboard Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Motherboard Replacement: 10 단계, 이미지 2/2
    • There is a wifi card underneath the large ribbon cable on the right.
    • Remove the plastic piece that covers the screw.
  11. Toshiba Satellite C55-C5240 Motherboard Replacement: 11 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Motherboard Replacement: 11 단계, 이미지 2/2
    • Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
    • Pull out the WiFi card.
  12. Toshiba Satellite C55-C5240 Motherboard Replacement: 12 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 12 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 12 단계, 이미지 3/3
    • Disconnect the 4 regular cables.
    • Carefully pull the cable parallel to the board, not up or at an angle.
  13. Toshiba Satellite C55-C5240 Motherboard Replacement: 13 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Motherboard Replacement: 13 단계, 이미지 2/2
    • Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
  14. Toshiba Satellite C55-C5240 Motherboard Replacement: 14 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 14 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Motherboard Replacement: 14 단계, 이미지 3/3
    • Carefully lift the motherboard from the edges.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Abdel Feliciano Gonzalez
회원 가입일: 02/28/17
722 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 회원
USFT-NANCE-S17S1G5
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 49
전체 시간: 7,033
