주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5240 Screen Replacement
필요한 것
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 2 단계, 이미지 3/3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: 3 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Screen Replacement, Back cover: 3 단계, 이미지 2/2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 4 단계, 이미지 3/3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: 5 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: 5 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: 6 단계, 이미지 1/1
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: 7 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 7 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 7 단계, 이미지 3/3
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: 8 단계, 이미지 1/2 Toshiba Satellite C55-C5240 Screen Replacement: 8 단계, 이미지 2/2
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: 9 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 9 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: 10 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 10 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 10 단계, 이미지 3/3
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: 11 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 11 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 11 단계, 이미지 3/3
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: 12 단계, 이미지 1/3 Toshiba Satellite C55-C5240 Screen Replacement: 12 단계, 이미지 2/3 Toshiba Satellite C55-C5240 Screen Replacement: 12 단계, 이미지 3/3
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Angela Rodriguez
회원 가입일: 02/28/17
261 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 회원
USFT-NANCE-S17S1G5
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 25
전체 시간: 2,432
