주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5268 Battery Replacement
필요한 것
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-C5268 Battery Replacement: 2 단계, 이미지 2/2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Greg Smith
회원 가입일: 10/24/16
347 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G1
2 회원들
안내서 12개 작성하였습니다
댓글 2개
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - 답글
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 46
30일 전: 149
전체 시간: 16,599
