주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5268 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55-C5268 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Hard Drive Replacement, Back Panel: 3 단계, 이미지 1/1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Hard Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-C5268 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Pull the two rubber stops upward to move them out of the way and free the hard drive.
  7. Toshiba Satellite C55-C5268 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Slide the hard drive to the right towards the stops. This disconnects it from the motherboard.
    • This will require some force to slide the hard drive.
  8. Toshiba Satellite C55-C5268 Hard Drive Replacement: 8 단계, 이미지 1/1
    • The hard drive can be lifted out for replacement.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Greg Smith
회원 가입일: 10/24/16
347 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G1
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 41
전체 시간: 13,636
