주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-C5268 LAN Card Replacement
필요한 것
  1. Toshiba Satellite C55-C5268 LAN Card Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 LAN Card Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55-C5268 LAN Card Replacement: 2 단계, 이미지 2/2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 LAN Card Replacement, Back Panel: 3 단계, 이미지 1/1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 LAN Card Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55-C5268 LAN Card Replacement: 4 단계, 이미지 2/2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 LAN Card Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-C5268 LAN Card Replacement: 5 단계, 이미지 2/2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 6 단계, 이미지 1/2 Toshiba Satellite C55-C5268 LAN Card Replacement, LAN Card: 6 단계, 이미지 2/2
    • Gently remove the ribbon cable from the clip its held in. Peel back the tape holding it in and pull the cable straight out. It is not necessary to unclip the holder.
    • The correct ribbon has a blue ends labeled with LAN.
  7. Toshiba Satellite C55-C5268 LAN Card Replacement: 7 단계, 이미지 1/1
    • Remove the two 5.0 mm screws, using a Phillips #1 screwdriver, once the cable is out of the way.
  8. Toshiba Satellite C55-C5268 LAN Card Replacement: 8 단계, 이미지 1/1
    • Lift the card out of the laptop to replace it.
결론
Ben Rounseville
회원 가입일: 10/21/16
471 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G1
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,348
