주요 콘텐츠로 건너뛰기
Toshiba Satellite C55-a5310 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55-a5310 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/2 Toshiba Satellite C55-a5310 Keyboard Replacement, Keyboard: 2 단계, 이미지 2/2
    • Remove this screw with a JIS #000 screwdriver.
    • This screw does not come out all the way.
  3. Toshiba Satellite C55-a5310 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
  4. Toshiba Satellite C55-a5310 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55-a5310 Keyboard Replacement: 4 단계, 이미지 2/2
    • Using the JIS #000 screwdriver, remove the .5mm screw.
  5. Toshiba Satellite C55-a5310 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55-a5310 Keyboard Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to remove the keyboard from the laptop.
  6. Toshiba Satellite C55-a5310 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C55-a5310 Keyboard Replacement: 6 단계, 이미지 2/2
    • Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kari Rodgers
회원 가입일: 02/08/18
482 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S16-G1, Nardone Spring 2018 Sam Houston State, Team S16-G1, Nardone Spring 2018 회원
SHSU-NARDONE-S18S16G1
5 회원들
안내서 15개 작성하였습니다
댓글 2개
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Anthony Francisco - 답글
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
Jeff Breuer -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 2,242
