주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-A5108 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: 2 단계, 이미지 1/1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: 3 단계, 이미지 1/1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: 5 단계, 이미지 1/1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C55D-A5108 Keyboard Replacement: 6 단계, 이미지 2/2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
결론
Michael Medeiros
회원 가입일: 10/25/19
150 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 245
