주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-A5108 RAM Stick Replacement
필요한 것
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: 1 단계, 이미지 1/1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 2 단계, 이미지 1/1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 3 단계, 이미지 1/1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 5 단계, 이미지 1/1
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: 6 단계, 이미지 1/1
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
결론
Geoffrey Souza
회원 가입일: 10/25/19
327 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 252
