소개
If you're experiencing unstable internet connections, not seeing available networks, or you see an error pop-up message on your Toshiba Satellite laptop, use this guide to replace the Toshiba Satellite C55D-A5108 Wi-Fi card.
A Wi-Fi card is for enabling a wireless internet connection from your computer to a wireless connection network.
In this guide, you will be removing the battery, hard drive, and back cover of your laptop. You will also be putting the components back together.
After performing this replacement, you should experience stable internet connections.
필요한 것
Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
Pry the cover off with an opening tool.
Gently remove the cover with your hands and place to the side.
Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
