주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-A5201 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: 2 단계, 이미지 1/1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C55D-A5201 Keyboard Replacement: 3 단계, 이미지 2/2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: 5 단계, 이미지 1/1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: 6 단계, 이미지 1/1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: 7 단계, 이미지 1/3 Toshiba Satellite C55D-A5201 Keyboard Replacement: 7 단계, 이미지 2/3 Toshiba Satellite C55D-A5201 Keyboard Replacement: 7 단계, 이미지 3/3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite C55D-A5201 Keyboard Replacement: 8 단계, 이미지 2/2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: 9 단계, 이미지 1/3 Toshiba Satellite C55D-A5201 Keyboard Replacement: 9 단계, 이미지 2/3 Toshiba Satellite C55D-A5201 Keyboard Replacement: 9 단계, 이미지 3/3
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55D-A5201 Keyboard Replacement: 10 단계, 이미지 2/2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Kari Byrd
회원 가입일: 03/24/15
614 평판
안내서 1개 작성함
Baylor, Team 6-5, Shaver Spring 2015 Baylor, Team 6-5, Shaver Spring 2015 회원
BU-SHAVER-S15S6G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 5,810
