소개
This guide will help you go through the steps to replace your RAM unit in your Toshiba Satellite Laptop. With this all you should need is a Philips head screw driver to remove the bottom panel on the covering on the laptop. You will also need new RAM, the laptop is built to hold two RAM slots but it is not mandatory to have two of them. If you have tried to use the troubleshoot feature in the laptop and it said you need to change the RAM then this guide will help you.
필요한 것
거의 끝나갑니다!
결론
