주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-B5206 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: 3 단계, 이미지 1/1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 5 단계, 이미지 1/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 5 단계, 이미지 2/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 7 단계, 이미지 1/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 7 단계, 이미지 2/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 8 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: 9 단계, 이미지 1/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 9 단계, 이미지 2/3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: 9 단계, 이미지 3/3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Michelle
회원 가입일: 09/17/15
175 평판
안내서 1개 작성함
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G5
4 회원들
안내서 18개 작성하였습니다
댓글 2개
Thanks.. Really helped out..
SpeedyBlanco - 답글
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 4,672
