주요 콘텐츠로 건너뛰기
  1. First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Once you take the screws out, take the battery off; it should slide off easily.
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Then, carefully take off the back casing of the laptop and set it aside.
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. This is where the RAM is located that you will be replacing.
    • This is where the RAM is located that you will be replacing.
  6. There are two clips holding the RAM in place.
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Gently remove the RAM and insert replacement.
    • Gently remove the RAM and insert replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Amodei
회원 가입일: 2017년 11월 30일
145 평판
안내서 1개 작성함
Coast Union High School, Team S1-G5, Hartzell Fall 2017 Coast Union High School, Team S1-G5, Hartzell Fall 2017 회원
CUHS-HARTZELL-F17S1G5
3 회원들
안내서 1개 작성하였습니다
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 261
