주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-B5206 RAM Replacement
필요한 것
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: 2 단계, 이미지 1/1
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: 3 단계, 이미지 1/1
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: 4 단계, 이미지 1/1
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: 5 단계, 이미지 1/1
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: 6 단계, 이미지 1/1
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: 7 단계, 이미지 1/1
    • Gently remove the RAM and insert replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
David Amodei
회원 가입일: 11/30/17
160 평판
안내서 1개 작성함
Coast Union High School, Team S1-G5, Hartzell Fall 2017 Coast Union High School, Team S1-G5, Hartzell Fall 2017 회원
CUHS-HARTZELL-F17S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 525
