주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-B5206 Trackpad Replacement
필요한 것
  1. Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Trackpad Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Trackpad Replacement: 2 단계, 이미지 2/2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Trackpad Replacement, Back Casing: 3 단계, 이미지 1/1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Trackpad Replacement: 4 단계, 이미지 1/1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Trackpad Replacement: 5 단계, 이미지 1/3 Toshiba Satellite C55D-B5206 Trackpad Replacement: 5 단계, 이미지 2/3 Toshiba Satellite C55D-B5206 Trackpad Replacement: 5 단계, 이미지 3/3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Trackpad Replacement, Trackpad: 6 단계, 이미지 1/1
    • Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
  7. Toshiba Satellite C55D-B5206 Trackpad Replacement: 7 단계, 이미지 1/1
    • Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
    • Gently pull the blue ribbon cable free.
  8. Toshiba Satellite C55D-B5206 Trackpad Replacement: 8 단계, 이미지 1/1
    • Use a small Philips screwdriver to remove the screw shown.
  9. Toshiba Satellite C55D-B5206 Trackpad Replacement: 9 단계, 이미지 1/2 Toshiba Satellite C55D-B5206 Trackpad Replacement: 9 단계, 이미지 2/2
    • Push the two gray tabs out on the large wire plug shown.
    • The tabs only need to be pressed out a few millimeters, not all the way.
    • The plug can now be carefully pulled out.
  10. Toshiba Satellite C55D-B5206 Trackpad Replacement: 10 단계, 이미지 1/1
    • Gently lift the trackpad to remove it.
결론
Elaine Butler
회원 가입일: 04/12/22
265 평판
안내서 2개 작성하였습니다
IUPUI, Team 1-2, Beck Spring 2022 IUPUI, Team 1-2, Beck Spring 2022 회원
IUPUI-BECK-S22S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 151
