주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-B5310 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C55D-B5310 Hard Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  2. Toshiba Satellite C55D-B5310 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the CD/DVD Drive out of the laptop.
  3. Toshiba Satellite C55D-B5310 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the thirteen 7 mm screws that secure the bottom cover.
  4. Toshiba Satellite C55D-B5310 Hard Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you start from a corner, and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  5. Toshiba Satellite C55D-B5310 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
  6. Toshiba Satellite C55D-B5310 Hard Drive Replacement: 6 단계, 이미지 1/3 Toshiba Satellite C55D-B5310 Hard Drive Replacement: 6 단계, 이미지 2/3 Toshiba Satellite C55D-B5310 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the hard drive from the blue rubber mount.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Crystal Loomis
회원 가입일: 01/22/18
732 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 66
전체 시간: 3,177
