주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-B5310 Touchpad Replacement
필요한 것
  1. Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: 1 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement, Keyboard: 1 단계, 이미지 2/2
    • Turn off your device before starting.
    • Flip the phone over so that the back camera is facing you.
  2. Toshiba Satellite C55D-B5310 Touchpad Replacement: 2 단계, 이미지 1/3 Toshiba Satellite C55D-B5310 Touchpad Replacement: 2 단계, 이미지 2/3 Toshiba Satellite C55D-B5310 Touchpad Replacement: 2 단계, 이미지 3/3
    • Use a your hands to remove the backing of the phone.
    • Use your phillips screwdriver to begin removing all the accesible screws.
    • Now begin to remove the coverings above and below the middle plate with your hand.
    • use your hand or a tool to remove the tabbing on the metal plate covering the battery.
    • Remove the metal plate covering the battery.
    • Use your wedging tool to begin removeing the adhesive under the battery.
    • Remove these two screws with your phillips screw driver.
    • Open the two metal tabs
    • Flip the phone back over with the screen facing you.
    • Begin to use the wedging tool to remove the space bar off of the keyboard.
    • remove the screws on each end of the space bars vacant lcoation.
    • Grab the wedging tool and begin wedging the old keyboard.
    • begind wedging the back of the keyboard until free.
    • Begin deperating the keyboard from the backing.
    • grab your replacement keyboard and connect it to the backing of the old keyboard.
    • place the keyboard back onto the front of the phone
    • once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
  3. Toshiba Satellite C55D-B5310 Touchpad Replacement, CD/DVD Drive: 19 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  4. Toshiba Satellite C55D-B5310 Touchpad Replacement: 20 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 20 단계, 이미지 2/2
    • Slide the CD/DVD Drive out of the laptop.
  5. Toshiba Satellite C55D-B5310 Touchpad Replacement, Touchpad: 21 단계, 이미지 1/1
    • Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  6. Toshiba Satellite C55D-B5310 Touchpad Replacement: 22 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 22 단계, 이미지 2/2
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  7. Toshiba Satellite C55D-B5310 Touchpad Replacement: 23 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 23 단계, 이미지 2/2
    • Release the clamps holding the white ribbon between the touchpad component and the motherboard.
    • Slide the ribbon from the motherboard connection socket.
  8. Toshiba Satellite C55D-B5310 Touchpad Replacement: 24 단계, 이미지 1/1
    • Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
  9. Toshiba Satellite C55D-B5310 Touchpad Replacement: 25 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 25 단계, 이미지 2/2
    • Release the two clamps connecting the blue ribbon to the external touchpad.
    • Lift the black clasp holding the blue ribbon in place.
  10. Toshiba Satellite C55D-B5310 Touchpad Replacement: 26 단계, 이미지 1/2 Toshiba Satellite C55D-B5310 Touchpad Replacement: 26 단계, 이미지 2/2
    • Slide the blue ribbon from the external touchpad holding socket.
    • Lift the touchpad module from the laptop.
결론
Crystal Loomis
회원 가입일: 01/22/18
732 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 886
