소개
If you are unable to use the touchpad of your laptop, use this guide to remove and replace the touchpad.
필요한 것
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
거의 끝나갑니다!
결론
