주요 콘텐츠로 건너뛰기
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
필요한 것
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 1 단계, 이미지 1/3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 1 단계, 이미지 2/3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: 1 단계, 이미지 3/3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 2 단계, 이미지 1/1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 3 단계, 이미지 2/2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 5 단계, 이미지 1/1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 6 단계, 이미지 1/1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 7 단계, 이미지 1/2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: 7 단계, 이미지 2/2
    • Pull the fan and heat sink away from the motherboard.
결론
Laura Tamayo
회원 가입일: 02/14/19
678 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 회원
USFT-LEAHY-S19S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 339
