주요 콘텐츠로 건너뛰기
Toshiba Satellite C55Dt-A5306 Fan Replacement
필요한 것
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: 2 단계, 이미지 1/1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: 3 단계, 이미지 1/1
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: 4 단계, 이미지 1/1
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: 5 단계, 이미지 1/1
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306  Fan Replacement: 6 단계, 이미지 2/2
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: 7 단계, 이미지 1/1
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: 8 단계, 이미지 1/1
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: 9 단계, 이미지 1/1
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: 10 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306  Fan Replacement: 10 단계, 이미지 2/2
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
결론
Nahrain Putris
회원 가입일: 01/17/17
329 평판
안내서 3개 작성하였습니다
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Oakland University, Team 2-3, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G3
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 405
