주요 콘텐츠로 건너뛰기
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 4 단계, 이미지 2/2
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 6 단계, 이미지 2/2
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 7 단계, 이미지 1/1
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 8 단계, 이미지 1/1
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 9 단계, 이미지 1/2 Toshiba Satellite C55Dt-A5306 Keyboard Replacement: 9 단계, 이미지 2/2
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
결론
zeena qiryaqoz
회원 가입일: 01/17/17
301 평판
안내서 3개 작성하였습니다
Oakland University, Team 2-3, Ruskiewicz Winter 2017 Oakland University, Team 2-3, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G3
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 705
