주요 콘텐츠로 건너뛰기
Toshiba Satellite C655-S5142 Keyboard Replacement
필요한 것
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Unplug your computer, and make sure that it is shut off before starting
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C655-S5142 Keyboard Replacement: 2 단계, 이미지 2/2
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite C655-S5142 Keyboard Replacement: 3 단계, 이미지 2/2
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite C655-S5142 Keyboard Replacement: 4 단계, 이미지 2/2
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Kozlowski
회원 가입일: 03/21/19
244 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G5, Valliere Spring 2019 UMass Dartmouth, Team S1-G5, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 336
