소개
Is your computer getting too hot to handle? Overheating is a sign that your cooling fan may not be working properly, which may cause further damage to your computer. This guide will help you through the replacement of the cooling fan in your Toshiba Satellite C655D-S5084.
필요한 것
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
