주요 콘텐츠로 건너뛰기
Toshiba Satellite C655D-S5084 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Shelby Kunz
회원 가입일: 04/19/13
69 평판
안내서 5개를 작성함
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 회원
CPSU-MANESS-S13S2G20
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 21
전체 시간: 3,515
