소개
If your computer is running slow and needs a little pick me up, one option is to replace or upgrade your hard drive. This guide will show you how to remove your hard drive and install a replacement in your Toshiba Satellite C655D-S5084.
필요한 것
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
