주요 콘텐츠로 건너뛰기
Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
필요한 것
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 1/2 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): 1 단계, 이미지 2/2
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: 2 단계, 이미지 1/1
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: 3 단계, 이미지 1/1
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Shelby Kunz
회원 가입일: 04/19/13
69 평판
안내서 5개 작성하였습니다
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 회원
CPSU-MANESS-S13S2G20
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 3,011
