소개
Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
필요한 것
Turn the laptop over and place upside down on a flat surface.
Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
