주요 콘텐츠로 건너뛰기
Toshiba Satellite C660 HDD / RAM Memory Replacement
필요한 것
동영상 개요
  1. Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: 1 단계, 이미지 3개 중 1개 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: 1 단계, 이미지 3개 중 2개 Toshiba Satellite C660 HDD / RAM Memory Replacement, HDD / RAM Memory: 1 단계, 이미지 3개 중 3개
    • Remove the battery.
    • Unscrew 1x Phillips screw and disassemble the HDD / RAM memory cover.
  2. Toshiba Satellite C660 HDD / RAM Memory Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Satellite C660 HDD / RAM Memory Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Satellite C660 HDD / RAM Memory Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic tool and an anti static gloves to pull out the memory modules.
    • If you have not, then hold the board only at the ends.
    • If you plan to make an upgrade, first of all check the specification of yours model. Depending of the Chipset and the producer, every laptop have a limit of the expansion of the RAM memory.
    • Check exactly type of the used memory modules. This models use DDR3 technology.
    • You can use modules with a different speed but the processor will work with them at the speed of the slower one.
    • Some modules will not work together.
  3. Toshiba Satellite C660 HDD / RAM Memory Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite C660 HDD / RAM Memory Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite C660 HDD / RAM Memory Replacement: 3 단계, 이미지 3개 중 3개
    • Now let's remove the HDD.
    • Remove the hard drive by sliding it away from the port towards the screw hole.
  4. Toshiba Satellite C660 HDD / RAM Memory Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite C660 HDD / RAM Memory Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the 4x Phillips screws and separate the HDD from the HDD caddy.
    • You can upgrade your HDD to maximum 1TB.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,943 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
3가이드 댓글
I dunno, I would class this as easy peasy. One captive screw. No need for tool to remove ram, it pops up when you flex open the metal bits. Doing it with fingers is way easier.
While you can remove the 4 screws to remove and transplant the bit of plastic onto the new drive, a dab of sugru to secure 20 quid ssd drive will do the job. Upgrading these things tales less than 5 minutes.
Beyond utility - 답글
Can I replace the HDD with a SATA SSD?
Steven Jamolin - 답글
To Steve Jamolin:No
WideRio Saeas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 71
전체 시간: 13,394
