주요 콘텐츠로 건너뛰기
Toshiba Satellite C675-S7106 Battery Replacement
  1. Toshiba Satellite C675-S7106 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C675-S7106 Battery Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
결론
Joshua Steakelum
회원 가입일: 03/25/19
451 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 163
