소개
Sometimes a CMOS battery needs to be replaced or re-seated - in this laptop, that’s a fairly simple and straightforward process. You’ll need a PH0-head screwdriver and a plastic tool to pry the battery from its socket.
필요한 것
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Rotate the laptop so that the battery cavity faces away from you.
Unscrew the single PH0-head screw connecting the center panel to the laptop.
Using a plastic spudger, unclip and remove the panel from the device.
