주요 콘텐츠로 건너뛰기
Toshiba Satellite C675-S7106 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite C675-S7106 Hard Drive Replacement: 2 단계, 이미지 2/2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: 4 단계, 이미지 1/3 Toshiba Satellite C675-S7106 Hard Drive Replacement: 4 단계, 이미지 2/3 Toshiba Satellite C675-S7106 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dinis Valcorba
회원 가입일: 03/26/19
292 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 회원
UMASSD-SIMCOCK-S19S1G2
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 378
